Samsung Gear S As My Main Phone & Hotspot For My Galaxy Note 4 (Wi-Fi Only) To Save With Verizon?
Dankees
Trusted Member
Mar 26, 2011
687
According to what I see online, I can share 6 GBs of data and pay about $10 less per month. Then, it's possible that I could get the Samsung Gear S (which can run on a SIM Card) and possibly use it as a mobile hotspot for my Galaxy Note 4 and then I could use my Note 4 over Wi-Fi and off of the Samsung Gear S (mobile hotspot) out of the house if I need a bigger screen (which doesn't really happen because I'm normally on Wi-Fi). The monthly access fee for the watch is much lower than the phone and would save hundreds of dollars each year (plus, I'd have 50% more data to share). Because the smartwatch can use a SIM Card, I can use it for the 5 calls I make or receive each month. Does that sound right?
Re: Samsung Gear S As My Main Phone & Hotspot For My Galaxy Note 4 (Wi-Fi Only) To Save With Verizon
Gear s can become a hot spot??
Nope. Even if it could it will probably last only 10 minutes. Also the Verizon version has no SIM card slot.
The Verizon one can't be a hotspot? How come the battery would die so fast?
No Gear S ever have hotspot feature, not just Verizon one. Hotspot can drain a regular phone's battery in an hour or two (which typically has a battery capacity of > 2000maH). Gear S only has a battery of 300maH.
Bummer. :-(
