Samsung Note 5, stops charging when plugged in
momof3b1g
I have noticed recently that my Note 5, that is only 5 months old. Is not charging completely before it stops charging. If I unplug it, and plug it back in(whether its on the phone end or the outlet end.) It will begin charging again. It seems to have started after the latest update to Nougat. Is there a fix? Is this related to the update?
Mine is working fine. Check the cable. I had a bad one, just like your problem, and had to replace it.
saujanya
