Samsung Note 9 shutter sound can't disable permanently
  • Start date Start date
A
Android Central Question
Hi, I knew I can remove the shutter file before Lollipop. Now I can't remove it from my Note 9. It's so annoying when I took pictures friends gathering, especially in the restaurants. Mute all function just a temporary solution, often I forgot to switch back to normal. Anyone successfully remove the file to disable the camera shutter sound? XDA forum so far no one knows the methods because I posted this issue and no answer.
Hi, welcome to Android Forums
I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
I'll provide a link to register, please come back to your post so we can further assist
https://forums.androidcentral.com/showthread.php?t=409154
Use the Routine app to set the phone to vibrate when in camera. It will auto reverse to previous sound profile when you close camera app
Wasn't it also carrier dependent? I use AT&T and I can just turn the shutter sounds off. I do know that other Carriers disallow that. Privacy concerns or something like that.
It's possible , carriers can do that
I thought it was also some countries that didn't allow it.
My phone is on silent since I wear my watch a lot. However I'm on Tmobile, usa, locked, and it did allow me to silence mine.
I opened the camera, chose settings, shutter sounds and silent toggle.
gbTopaz
