Samsung OEM GS3 Slim Cover 2 pack pattern cases
Ordered mine direct from sammy, just got them today. It's exactly what I wanted - something to protect the sides/back/camera from scratches and very light falls while not bulking up the phone. Fits perfectly too.
Galaxy SIII Ultra Slim Case
Damn, ansextra, you might be right. This one doesn't say "Ultra SLIM" so maybe it is different. Dammit. I just want it to fit with the Infuse car dock. Hope it still does.
Has anyone found a slim case that will still fit the Infuse car dock?
Did you buy those on line or at a sprint store? i ask because i cant find a two pack with both clear, only blue and clear. i have 2 gs3's, one for me and the other for wife. we both want the oem clear one but i cant even find it at Samsung website. you wouldn't still have the box with the Samsung model number or upc code on it do you?
I Bought these cases a few months back and they have scratched the back of my phone terribly due to the constant rubbing and the raised design of the cover. I have used bother and now have both diagonal lines and dots rubbed into the back of my phone. The cover is also very hard on the corners of the phone so the Blue has worn off the corners.
Anyone else had these issues?
Be careful if you do use them. I eventually put some transparent film between the cover and the phone to stop the rubbing. Unfortunately it's too little too late and the damage is done.
s1atoshi
