Samsung S4 rooted custom boot animations issue. Any help?
  • Start date Start date
A
AC Question
Samsung s4 rooted custom boot animations issue.
Hello guys, I need help trying to get my boot animation that I downloaded to work. I rooted my device with kingroot and it works perfectly that my device is rooted correctly. I used the root browser and boot animations app by Jrummy or something like that then I grabbed a watchdogs bootanimation on the net named bootanimation.zip, it is has two parts and has the resolution of my s4 at&t i337. I installed the zip to data/local (didn't work) I checked the permission status and made sure they read rw-r-r. Then I installed it to system/media and that still didn't work. I realized that the boot animations were not being overwritten so I tried to rename the boot animation.zip to bootsamsung.qmg to replace the stock manafactuar boot animation and no luck. I searched everywhere on the Internet for a answer and they provided the same one that didn't work. If you guys want screenshots or the zip I can try to post it. But I would appreciate some help ASAP.
uOttawaGrad_22
