Samsung Tectiles
I'm planning on putting a TecTile in my car dock (whichever one I end up getting) to turn on bluetooth, gps, and go into car mode.
Hopefully when I remove the phone from the car dock that will automatically turn all those functions off.
This. And exactly the same when I put it into the holster/case and remove it.
THAT, to me, would be the huge advantage of these over tasker. Helping the phone to auto-magically KNOW where it is, and based on that knowledge, do something automatically that COULD be done with tasker, except the phone would have no clue WHEN to do it.
Here is a thread on general NFC stuff and covers some third party NFC apps, and has links to other articles and sources for tags.
http://forums.androidcentral.com/htc-evo-4g-lte/174968-nfc-uses-apps.html
Edit: There is also a NFC app that will let you re-use tags that you might find on something you purchase. Instead of relying on being able to program the tag, it reads the tags serial number then uses an internal database to assign actions to that tag. Of course that limits the flexibility, of having a tag that does the same thing for many phones without having to program it for every phone, but it saves you $1/tag so if you are on a budget... https://forums.androidcentral.com/e...m.widgapp.NFC_ReTAG_FREE&hl=en&token=ItxAR3bK
andiox
