Samsung Universal Gingerbread Root & Unroot 2.3.3 -> 2.3.7+
Did you root your phone successfully with this method?
  • Total voters
Worked for my Gravity Q!
Found this form when this page showed up in my searches. Gonna take a look around now.
Hi Sir. I was wondering if this works for Smart (PH). My phone is simlocked with that network. And it was not listed in your post. What will happen if I try to root then?
And I would like to try rooting my phone, then upgrade it to ICS or JB.
Thanks.
The new downlod is on a "complete survey to download" site which as usual doesnt work can please post an actual download link
Hi Guys....I have a Samsung Galaxy Y GT-S5363..I am finding it so so so hard to root it....
I put the update.zip on the root of my sdcard, then into system recovery and applied the update and it then stats but then says:
ice" == "GT-B7510" ||getprop("ro.product.product") == "GT-B7510" :Error in /tmp/sideload/package.zip
(status 7)
Installation aborted.
is it because my phone is a s5363? and not a s5360?, will this work adding it to the updater script??
I was told :
Like below add that
getprop("ro.product.device") == "GT-S5363" ||
I am now trying to install "universal gb root unroot"....but the links and all stuff here on 1st page is lots and lots of surveys...even after taking surveys
PLS HELP.
I've been trying to root my S5830 for almost a year now, and reading the reference to the carrier branded system files, I thought I had my answer with the universal_gb_c.c.b.s.f_v9.zip. Unfortunately the download just takes me to a site that tells me I must complete a survey before I can download it. I've been to this site on several occasions before, and signed up to their $5/mth subscriptions as demanded and still can't download the file. I tried again today, and still get the same result.
Is there any way to obtain this download without having to sign up for these costly and useless competitions, and still not get the file?
I just want to download it, and I'd be more than happy to pay for it. I don't want to upload it to another server. Your posts are full of promises, and deliver nothing!
can i ask a question? after i complete the survey its stock on the processing i can't download the file. please can you help me? thanks in advance i'm just new here. :3
Please Complete A Survey To Download This File
There are no surveys available for your country.
Please use valid information when fill any survey otherwise your download will not start and the survey will not finish.
Download will start after you complete a survey above, usually it takes 2-3 minutes to check after completion.
@$%^& Unable to download the zip file without having to fill crappy SCAM survey that only wants my phone number or email address to start bombarding my phone with 2$ txt messages and anyway it's not available with my carrier, of course it's scam!. What a waste of time and since you have no clue what this zip file actually do ! I will not install this as it could easily be installing a backdoor for hackers, you should be able to type the commands in a terminal window and supply the root password, because this is in fact the only thing you actually need to root a linux device
odigon
