Says charging(USB) while I am using (AC)
Note 3 user
21
My Note 3 sometimes says that I am using USB charging while I am connected to a wall output. At these times it charges really slow. It can be solved by removing and re plugging the cable into the phone several times. Is there a simple solution to this like getting a new cable? Right now I am using the stock cable.
It could indeed be a USB cable issue or a it could be a charger issue. It may be worth buying another Samsung charger not only to troubleshoot but just to plug in elsewhere.
Sounds like a cable problem - I've been doing some testing with various USB cables and posted the details here: http://forums.androidcentral.com/sa...rging-cable-testing-results-surprised-me.html
There is a link to an app that can help you see what is going on and some links to technical explanation as to why some cables will slow charge and what to look for when buying new cables.
If the phone is relatively new I have read about a few people that have gone back to the store and got a new cable (YMMV).
Beanz2003
