Screen Lock and dial volume
milwaukee613
114
9
I dont know if anyone else has had this problem, but suddenly my screen lock and dial volumes went really really soft. I tried messing around with the settings but nothing worked. I even went as far as to modify the lock.ogg file and make it louder, but nothing worked.
Eventually I downloaded audio manager, and with its easy to use system, I just simply increased the system volume. This solution worked.
Let me know if anyone else had this issue, and if there is a simpler way to fix the problem of a low lock and dial volume, then the way that I fixed the problem.
Just thought Id share my problem and solution.
Peace
I had the same issue. Download quick settings from the market, that fixed my issues
Sent from my ADR6400L using Tapatalk
yeah, this happen to me this morning. here is how i fixed it. try this and see if it works.. it worked for me
1. Opened Maps and entered a location
2 . Tried to get directions to location
3. Told it to open Google Navigation
make sure your GPS is Enabled.
Ishimwe
