Screen protector for s10+?
It is not glass, they just used the same packaging as their glass protectors. I just installed mine, it's pretty nice but my installation wasn't great. A couple of bubbles and I didn't get the right edge down as nicely as I'd like and the edges want to unstick. They give you 2 per pack and I got 2 packs. For $8 US it's a okay.
That's not good. The edges do not stick down good?
Can you link to the product where you got it from, please? The listings on Amazon say it's not glass?
It’s not glass, I bought a pack the other day and installed it last night. I got one tiny speck but I can barely tell. And I’m not sure if it’s like this for others but my protector doesn’t fully reach the edges. It cuts off and leaves a sliver of edge not protected on both sides. But other than that, I love the protector. The FPS works good, I did set them up after I installed the protector though.
So far mine is holding up nicely. Edges aren't coming up, nice and clear, minimum fingerprints. It's definitely not edge to edge but looks fine with the Spigen Rugged Armor case.
Nope, the factory plastic is holding just fine for now. My FPS is pretty bad with the factory plastic, can only imagine how bad it would be with the dome.
Yeah if your having hard time with the thin factory screen protector other ones probably a no go.
Verzion put a zagg on the s10e yesterday when I bought it. They said it did not come with one, but looks nice on this flat screen.
I've just installed one of these today: https://www.amazon.co.uk/Masstimo-P...ag=hawk-future-21&ascsubtag=UUacUvbUpU6525862
Messed up the first attempt; perfected the second :)
I managed to nick the edge of the OEM protector last week and it lifted too much, so had to remove it. Used an iBlason Ares case with the built in protector in the meantime until these arrived (which they did, but I forgot that I'd put them in my top drawer) haha
Installed today and it works very well indeed. Fingerprint sensor is flawless and it's as slick as the OEM protector.
Thinking of trying the Simply Carbon Fiber screen after seeing their YouTube video. This would be a first as the curved screens for all recent Galaxy devices have gone commando.
Aren't they plastic film? If so they are less expensive optuonsy
I have this on my S7. If you can get a good install without any dust, they're pretty good.
Thanks. I'm using my wife's GS9+ as a test. She has cracked every tempered glass screen protector were sold at the AT&T store. Her phone spends time in her purse and has rarely been abused otherwise.
cepat_tanggap
