Screen protector for s10+?
I saw at my local Walmart today that they have the Blackweb brand of glass screen protectors for the S10 series of phones for $15 (S10e was $18 actually for some reason) if anyone wanted to give them a try? I still have my factory screen protector that I'm okay with.
I haven't used Whitestone yet, but I'm a supporter. I'd be willing to try the Blackweb. Go ahead and send me one.
I order the Whitestone for my S10+. Excellent screen protector. The only problem that I ran into was that it was not compaitable with my Otterbox Defender series case.
So, I am now resorting to a Zagg, in which I have always used and have had great luck. Needless to say, Otterbox is back on and screen protector did not push off in the corners like it did with the Whitestone.
Well I finally noticed a knic in the stock sp on my ceramic black. . I guess I’ll buy that OTAO.
I pre-ordered a front and back protector from RhinoShield. They finally brought back their impact protection screen protectors for the S10 series after offering typical tempered glass the last two years. The one I've used on my current Nexus 6P has served me quite well, saving my screen from countless drops, including face first on concrete. Best part is you can clean it with a tiny bit of soap in some water, squeegee it out and it'll reapply good as new. Hopefully this new reformulation is just as good.
https://rhinoshield.io/pages/shop/S...prod=samsung-galaxy-s10-plus-screen-protector
I should be receiving my OTAOs today. Looking forward to removing the now-blemished factory sp.
Got mine also but going to roll with the factory one for a little while longer.
Please let me know how the installation goes and how it compares to the factory plastic.
My OTAO came today as well. Install was quick and easy. FPS works like there's nothing there...quick and no misses (for me). Crystal clear and smooth. I'll see how it holds up as far as daily use goes.
Mine came but I’ve not even opened the package yet.
Can you link to the product where you got it from, please? The listings on Amazon say it's not glass?
It is not glass, they just used the same packaging as their glass protectors. I just installed mine, it's pretty nice but my installation wasn't great. A couple of bubbles and I didn't get the right edge down as nicely as I'd like and the edges want to unstick. They give you 2 per pack and I got 2 packs. For $8 US it's a okay.
InKatysOpinion
