Screen protectors
I think I'll be going with the Zagg. It's easier going to the mall and having them install it. I haven't had the best luck installing screen protectors in the past.
So what screen protectors are people getting? I'd like to try a tempered glass protector this time, are there any recommendations?
Also, crazy question, but is it even possible to get a glass screen protector without the vertical strips of glue on the right and left edges? In the past I've found that this sort of ruins the effect of the infinity display.
I've never used any screen protectors on the GS6 edge, GS7 edge or the Note 8, but I got one to test on the Note 9.
The Whitestone 2 pack for the Note 9 is on sale with code GALNOTE9 for the price of one at $44.99.
Another member shared it on another thread.
I've got it and will arrive Friday, I hope it's good.
i went with the Spigen NeoFlex. it's not fully settled in yet because i just installed it but it's working great so far.
No screen protectors for me. Zip, nada. Had my Note 8 since September of last year with nothing on the screen since then. I have no scratches, cracks or anything. So, nope, not for me.
same here. No issues with my s8 plus, note 8 with no screen protector. I keep it in my right pocket with nothing else in the pocket and I use the Defender which has large generous lips on it.
I might get some cheap generic tempered glass the suppliers I buy from use just to try out on the phone and see what it's like. If I don't like it then it only cost me at cost a couple bucks.
All right I just ordered the Caseology tempered glass screen protector for $11.99:
http://a.co/d009Ma4
For whatever reason it isn't available via Amazon Prime, but it's cheap and should nonetheless arrive before the Note 9. I'll probably get a 2 pack of Spigen Neoflex screen protectors as a backup in case this doesn't work out, but we'll see how it fares!
Does this screen protector have adhesive only on the edges or all over ?
I got this one. Totally screwed it up putting it on.
My hand slipped and now I have bubbles.
How much is it? I think I saw somewhere that was 40 odd dollars for two. Do they sell it solo for one LOL
With the 30% off of the 2 pack, it's cheaper than the single. IMHO, it's worth it. I wish I would've put one on the Note 8. I do recommend watching a couple of install videos first.
BekaH
