Screen turn on automatically
My S9+ just started doing this tonight..... anyone have any real luck finding the problem? I'm taking mine to the sprint store tomorrow....
When the fone starts to get awry ..
4 things to do ..:
1- Use Samsung smart switch to back up your fone
2- Wipe system cache partition ..
3- Last solution : do a system reset .
4- Option if allow .. bring it back to the store and get another one ..
Cheers .
I had the same issue. Most of us thinks so advance that we forget to check the basics. The cause of my issue was my cp cover/case. One the side buttons (Bixby button) is permanently pressed by my cellphone case/cover, causing the screen to wake up every 50 to 60 seconds. I removed the case and voila no more issue. Will find a perfect case for my phone.
Try this
Hi I was having the same problem my phone would light up the bedroom in the middle of the night, drove me crazy but I took a deep breath and figured it out after a while !!
Try this it worked for me
Go to
Settings
Accessibility
Advanced settings
Notification reminders turn it off that will make it stop
Let me know how it goes
Melanie T
Gulnaz
