screen turned yellow!
Well I had the my galexy s3 screen turned yellowish today after installing reservation remix naugat version 7.1
I just went into live display option and adjusted the color saturation to 6500k the screen turned normal after that.
I tried. It just went back again after i exited the settings. It comes that it only works on settings is open.
So for everyone I had this same problem. I fixed it by opening up play books. There is an capital A icon. When you click on that then click the brightness icon on the right side. You should now see night light and settings next to it. This was turned on always. Once I turned today if everything was fixed. Not sure if this was your issue but this solved my problem.
My phone is real old, but I only get to experience this yellowish, orange screen just this past few days and right now, It goes on randomly and goes on for more than 30 seconds if you don't press the homescreen button, I was looking it up in youtube but all of the explanations are not good so I looked it up again in google and found this website, and rn still struggling with yellowish screen, so i saw a vid about how to fix this and the guy said that you need blue ray for this,
Do I really need it just to fix my phone or is there another way?
Please reply if you know how to solve this problem, the struggle is legit hard
So for everyone I had this same problem. I fixed it by opening up play books. There is an capital A icon. When you click on that then click the brightness icon on the right side. You should now see night light and settings next to it. This was turned on always. Once I turned today if everything was fixed. Not sure if this was your issue but this solved my problem.//uploads.tapatalk-cdn.com/20180816/98c2bc7eeb000cdc11a69df938c33b51.jpg//uploads.tapatalk-cdn.com/20180816/757e835a27c56ccf9b87b570cdf8ea88.jpg
Yes, this was the fix for me, too. Everyone responds saying it's Blue Light Filter because it's another implementation of the same feature. It SHOULD be scoped just to Play Books but somehow leaks into the whole display system.
Drove me nuts... Thank you!
Why is my screen having this yellowish tint covering the whole screen..it started off doing this for just a few seconds and a day or two later it went full yellow tint on the whole screen. I found when I lowered the brightness it went off but have had to gradually lower the brightness as low as it will go and now if I turn the brightness up even one notch it goes complete yellow.. not sure if it's moisture related or what but it's really cold outside and I go inside and it's really warm is this the cause possibly.. I read something about this on another thread just curious for some more input possibly.
alejandro109322
