SD card and Media Problems- help?
sunsolar123
My atrix was working great, would use it all day playing pod casts and other moderate to heavy use all day with no issues getting 8-10 hr before charging Was rooted but then updated to latest software a while ago using Motorola pc updater. Did not add anything new to task killer only difference was i used slacker most of the day Then plugged it into my computer to add some new music, then i would try to play music from sd card "touch to select music widget" and phone would just hang or freeze till i pressed on off button or sometimes back button multiple times, occasionally it would just return to home page by itself . I also noticed under battery usage "Media" started using 30%-60% battery which i have never seen even listed under battery stats before.Once i did a force stop it would then allow me to select music from SD. I tried battery pulls, cycling power and media would once again appear under battery stats -same issue. I then unmounted sd backed up to my computer and remounted and performed format of sd card(which was suggested on forums to other people with sd issue). Any suggestions???
Much appreciated.
