SD card problem-Android 5.1
AndreNunes
3
Since reseted my phone to factory settings I have had problems with the sd card, it usually works for a while and then not with acessalo the file manager or shows in config / starege, but I can see the pictures and listen to music pello album and player.
When I put off and put back, works but then reboot and disappears again.
Sorry For My Bad English.
First: https://talk.sonymobile.com/t5/Xperia-Z3-Z3-Dual/Best-micro-sd-card-form-z3/td-p/906281
If your card isn't listed by Sony as a compatible card it doesn't mean that it won't work, just that Sony won't guarantee it.
Also you don't say what brand of card your using?
How fast it is?
Weather you've installed any new apps?
The default is to write to internal memory, but you could check to make sure nothing's writing lots of data to the card.
Also try unmounting then mounting the card.
If that doesn't work you could try backing up the media files, then wipe the card from the phone and see if that solves the problem.
Good luck, and check the Sony site for more information on micro SD cards and the Z3
Sent from my D6603 using Tapatalk
Have you tried another SD card yet? SD cards can fail and there are also many imitations of brand name cards (like Kingston) that can cause problems or be unreliable.
linksanthony560
