sd wipe help
kirurus
170
28
I can't reboot into recovery..even if I remove the battery the sd logo remainns..it does't completely power off. and yes I did a back up
Is the phone still plugged in?
*edit*
Also, I believe the only way to make a larger sd-ext partition is to get rid the one you currently have using your computer and creating a new partition.
Abdul Ali
