security update Verizon
Several times....I think its fine just annoying... I might connect to the software assistant to see if it picks up anything
Ok, yeah, hope that fixes it for you. I notice a speed boost now as well, but it gets terribly slow when installing app updates still.
Just weird.... Error message but I have right update installed and when I run system update check its fine
Looks like they simplified the recovery menu access. You no longer have to wait for the opening animation to use power+ vol down. Press and hold those two from the start and it'll show the LG splash screen, then move right into recovery.
I thought it did that already
At least you got a update did you get the latest security patch updates??
maryhurst515
