Seidio Innocase Extended
I don't think there are any clip holsters that work with the silicone cases. I believe some have gotten modified silicone cases into pouch type holsters for the EVO or other phones that are slightly bigger.
For what it's worth, the Seidio Spring clip works with the 3500 battery sans case.
Hope this helps.
Hope this helps.
... That leaves only the front and sides to protect. This case does nothing for the front, so it's not much value add. It mostly appears to protect the sides.
I too had a "meh" reaction to it. Nice enough but they should just make the door wrap around.
I've ordered an extended battery and this case as well. I wonder about your comment "does nothing for the front." To me, it looks like the case extends slightly forward from the face of the phone. Please correct me if I am wrong. But that is one of the reasons I want a case - extending even just a bit in front of the phone means you can lay the phone face down and protect the screen - so the phone isn't sitting on the glass.
Laying the phone down on its face with the "case" on does not touch the glass against the surface. There's about a 1mm or so clearance. Just wanted to clarify.
An innocase 2 for the extended battery would be a better idea. I have the innocase 1 now and it's OK but the 2 IF made for the extended battery is would buy in a heartbeat!
krinamukti
