Sept 10 T-Mobile G3 Update
VoLTE is a Verizon thing if i'm not mistaken. Tmobile already supports HD voice when both callers are on T-Mobile, so most likely the update won't enable VoLTE. If anything an update might make your phone compatible with whatever verizon has planned, whenever they decide to do it. lol
You are mistaken, T-Mobile is also implementing VoLTE on its network, several devices were already enabled for it, for some reason the G3 was not initially.
I had the update and it failed to install for some reason, now when I check there is no new update available and I am still on the old version, anybody knows how I could get back the update?
Posted via Android Central App On My T-Mobile LG G3
Ok so VoLTE is completely different than HD voice? I'm assuming that VoLTE would includes all carriers whereas HD voice right now is just T-mo to T-mo.
They're completely seperate. They can be implemented at the same time: you can have HD Voice over VoLTE. VoLTE doesn't not technically have to be HD Voice though, and HD Voice doesn't necessarily have to go over VoLTE.
VoLTE is the pipeline that T-Mobile is using to carry voice, and HD Voice is the quality of said voice. Think of it that way.
Ok I guess Uncarrier7 is what our update was all about, I bet it's for that seamless WiFi. "WiFi improvements" way to not spoil it. But it was a bit of a giveaway when all the other flagships got "WiFi Improvement" updates too. ;)
When you say you've checked, I take it you mean the Update Centre app, not just the notification pull-down?
Does anyone else with a G3 have lag in their dialer when they try to dial a phone number? I've tried other G3s and none of them have the issue.
Exactly! Checked more than once like every hour or so by updates and nothing
Now this usually works is shutting your phone down & power up after a few mins.....Good luck :-)
got the update, installed it, lost root.... purpledrake and stump root not working..... HELP!!!!!!!!!!!
guys i need your help............ got the update, installed it, lost root.... purpledrake and stump root not working..... :(
Maybe I'm doing something wrong.... all I get is a screen with dots and the program is still running....... help please!!!!1.png
beats me then, I'm sure the smart guys will update the root programs soon to cover this change
ThorTheBrotheren
