Serious Evo Problems
twsmale
4
Okay, so I was trying to flash a new ROM (MIUI) on my Evo, but it seemed to not take. As I was playing around with it trying to make it work, I ended up doing a full factory reset of my phone. I was running everything through the clockwork recovery mod, so I have a backup of my whole phone saved on my SD card. As of now, that's what I want back.
So in trying to make the ROM work, it did a full restore, so I decided to flash the PC36IMG to try and get it back to normal, because I couldn't even get it to boot into recovery, just the bootloader. Now, my Evo claims to be "S-ON" (it was rooted before with unrevoked), and when it boots into the normal stock image, it will not recognize the SD card (says "SD card removed" in the notification bar) and it will not charge or be recognized by my computer or ADB. I've tried re-flashing the PC36IMG several times, but I have the same problems.
Any ideas on how to re-flash the clockwork recovery mod and re-boot with my backup? I wish I could get it to be recognized by ADB so I could push the recovery file over, but I couldn't pull it off. Need help badly..
Also, if I try to reboot from the hboot or from recovery, it will turn off, vibrate 5 times, flash the green LED and stay off...
I've been scouring the internet for forums and I seem to have several problems from each different forum.
Update though, I got it to recognize the SD card with this command:
fastboot oem enableqxdm 0
fastboot reboot
Ugh, I am sooo close. I managed to get clockwork on my phone and restored to my backup. Everything looks good except for two problems.
I still have S-ON. I want to run unrevoked or another rooting method, but now I can't because every time I boot my phone, it stays on for about 5 minutes, then the screen goes black and it vibrates 5 times while blinking the green LED.
I have seen a ton of posts about this, but no one seems to have a good explanation for this. Any help at all?
joelkmason
