Serious snag when flashing nexus 7 2012
Kristal9
4
I got so tired of 5x running slowly, crashing and otherwise not working properly, and I was yearning for my beautiful and fast running tablet of a couple of months ago (before I foolishly accepted google's OS update to 5x).
I followed the instructions in this video exactly http://forums.androidcentral.com/go...1477-guide-nexus-7-factory-image-restore.html, but when the procedure was done, the device failed to reboot as his does in the video. It just stayed on the bootloader screen. So, and this may have been a mistake, I executed the flash command again. Then I got a message in the terminal saying fastboot had failed. I closed out of the cmd window and tried rebooting the nexus. Now it is stuck on a screen that just says Google and has an unlocked lock icon at the bottom.
So what can I do? Anything? Any ideas?
UPDATE:
Ok, I just tried redoing the procedure. I get this error as the rom is being written:
sending 'system' (644062 KB)...
FAILED (data transfer failure (Too many links))
finished. total time: 10.258s
The same thing happened last time... So I am guessing that is the issue. I will try it with an earlier kitkat and see if that goes anywhere.
It was a bad USB port. So if anyone else gets the same failure, try a different USB port. I have everything working fine, now.
nwnjzp42432e
