Setting for not having calls go to the Gear 2 neo
ronr9286t
4
I have the Gear 2 Neo connected via Bluetooth to my Note 4. I use a Bluetooth headset to answer and make calls. Occasionally, an incoming call will go to the Gear 2 instead of my headset. How can I prevent that (I still want the call notification to go to the Neo)?
Ron
Try going to your Bluetooth settings screen. Select the gear (settings) icon on the right of your Neo's name. You should have the option to select or de-select using the watch for "Call audio". This setting should be in place for your BT headset, as well. If it's an occasional problem, that might not be the issue. But it's a good place to start diagnosing.
YohimbeMale
