- Jan 23, 2013
- 2
- 0
- 0
I was thinking about switching from Verizon to an unlocked phone, most likely the Nexus 4. I am probably going to use Straight Talk as my service, but how do you generally go about doing this? Do I have to port my number directly over to straight talk? I would prefer the option to possibly switch services in the future, but keeping my same number is a must. I have heard Google Voice helps with this, but how so? On a sidenote, is it possible to buy a plan like their $30 one on a smartphone, which doesn't include data? I am only wondering in case I find I don't always need that much data, so I will have the option to save a bit of money every once in awhile with the option to switch back to a data plan later. Here is a link to all of the plans: https://forums.androidcentral.com/e...lk.com%2Fsecure%2FServicePlans&token=V8VWwPY2
Thanks!
Thanks!
