[SGSIII][Sprint] Android Central Rom and Kernel Library
How do you like the kernel? Is it faster, slower, one of those battery saving ones?
Do you recommend flashing it for Clark's rom?
Hi on that t-mobile Rom is it any good to much to read on I know they said mms is not working but beside that is it worth trying out
iTz Young Amazed
iTz Young Amazed
Honestly I love it, however the screen orientation is backwards. When you flip your screen one way it rotates the opposite. There is a work around by using an app called Ultimate Screen Control (I think that's the name) but when you go to take pictures... they will be upside down and there is no known work around for that. I would say, if you don't mind dealing with issues and trying it out ...go ahead cause I like it. If you're looking for a daily driver...I would say pass and go for something else.
iTz Young Amazed
The data toggle in the notification toggle is missing. Which is completely unacceptable. Several apps that i need will not run on it. Stock messaging app won't receive mms. I've been running for less than 2 hours it has gotten so hot that my phone cover is getting hot spots and discoloring (turning brown). I have also seen random reboots just scowling through the home screen.
Wow...i didn't even attempt the new one. I couldn't get past the screen orientation issue lol.. I just loved the way touchwiz is with jellybean.
Which T-mobile ROM are we talking about here...I want to be sure I avoid it at all costs, since I'm looking for a good driver to play with this week (Monday is usually my "change my underwear, change my ROM day...so I'm doing the ROM first -- mostly because my underwear are a little sticky and I want to have my phone tweaked first)
It was very smooth and the issues with some of my needed apps not working, has more to do with the app not being compatible with jb than jb.
It really isn't a T Mobile Rom. It is a T-Mobile JellyBean leak that was ported to Sprint. If you have a Sprint gs3, there are issues with the port.
If you are on T-Mobile you could use the T-Mobile leak without some of the issues. But don't load the one ported for Sprint, use the one for the T-Mobile.
Hey skunk. Do you have any idea why my phone keeps freezing then saying android is upgrading? It's starting to happen like every other day and its pissing me off because most of the time I'm in the middle of something. Still running Clark's rom. v1.0 had no real reason to upgrade to 1.1. Could my problem be with the rom, something else, or is this natural?
Sorry I haven't updated so couldn't tell you. I just flashed the radio only.
Anyway... Uncle Louie is absolutely correct. New ROM Update. AnaKonda Rom by TeamVenum's dazednconfused. If you liked Wicked Sensations you gotta try this one out!
It's all good. Thanks. Been getting kind of bored with Clark waiting for jelly bean anyway. I'll make my back up and probably flash anakonda tonight :D
I haven't been on a touch wiz Rom since stock. I'm getting a notification from Sprint saying there's an update. If I update, will I lose root access? Sorry ahead of time if this has already been asked.
jeffnachatilo
