[SGSIII][Sprint] Android Central Rom and Kernel Library
The kernel supports overclocking, underclocking, voltage adjustments. It has an assortment of governors and schedulers. There are more things you can control with this kernel over the CM10 stock kernel.
A word of warning if you decide to undervolt be careful with the values you set some may cause the phone to become unstable and reboot at will.
Sent from my SPH-L710 using Tapatalk 2
Reactions: Skunkape60
So i tried to change the bootanimation on the paranoid ROM and somehow messed it up. I downloaded cut and pasted using ES file explorer. Copied it to system media and.....it won't take!!!What have I dome wrong? How do I fix? All that comes up is the word android. I've tried 2 different boot animations.
Yes, I downloaded root explorer and that did it. Thank you though. Question though maybe this isn't the right place but how do you get the ones with sound?? What's the difference between these and flashing them??
Good that you were able to get it working. I just know that some people have better luck pushing animations to the data/local folder as it will override anything in system media.
Sorry, I don't normally mess with boot animations and definitely not ones with sound. I prefer no system sounds.
I Flashed the Tmobile jellly bean rom and the sms fix however the sms fix isnt working. I went to xda and i cant post questions and see nothing about how to fix. Can anyone help??
Fixed!! I found out what I did wrong. I needed to flash the sms fix directly after the rom before I reboot it.
This tmob rom is my FAVORITE thus far!!! It has horrible problems though mad::(:(:(:(:(:(:(:(:(:(:(:( I dont know who is running it but fix soon please!!!!
When flashing the Jellybro rom, do I need to flash the CM10 gapps??? How should I flash the rom exactly?? I also see a md5sum: 377eb02b5121c1f2d3f50349bdbd0c94 what is this exactly???
Yes, make sure to flash GAPPs (unless it's somehow different than w/ Nexii).
md5 = a number used to verify that what you downloaded is exactly the file described/listed.
The Gapps for the CM10??? Like the ones that came with the Paranoid ROM or do I need different ones??
Has anyone else had problems with the battery mods in the update me app for the sonicROM?? Also, will wicked sensations be coming up with new themes anytime soon?? The black and blue was getting to me for some reason idk, maybe my OCD.
Yup...Issues with the battery mods are posted all over his thread.
Yes, Dazednconfused is bringing another one of his roms over from the epic touch. It was called Anakonda Rom on the epic touch and don't see him changing the name for the gs3. So it's in the works...
xda-developers - View Single Post - [ROM] [Team Venum] ヅ Wicked Sensations Rom v1.1 (UPDATED 8/26/2012)
This is a sample from the epic touch forums...
[ROM] [TeaM VeNuM] [FF18] ヅ AnaKonda Rom 2.0 - FF18 - TW/Sony ICS 4.0.4 - xda-developers
This was my favorite ROM on my Epic Touch (didn't even realize that it was dazednconfused's ROM; no wonder I liked Wicked Sensations so much! ), so count on it being even better on the SIII. :eek:
New update... And yes! It's a KERNEL! Morfic's very popular Trinity Kernel has finally made it's way to the Sprint GS3.
Sitole Reshid
