[SGSIII][Sprint] Android Central Rom and Kernel Library
I'm having issues with blazer not allowing root access. When I open a root app I'm not even prompted to confirm or deny it just automatically denies it. I was able to grant superuser access but that's it. I've already tried setting su to grant root access by default.
Look at the "Trying to root but can't get into recovery" thread in these forums too. The last post has a link to what you need. If that doesn't work, there is another SU zip in the XDA Blazer forum that will work.
Re: Android Central Rom and Kernal Library
So far this Blazer ROM is very nice. Everything is very smooth and I've been on the same battery for 1d 2h 58m 19s with 24% left. I've been doing LOTS of web browsing, downloading, moving widgets and apps and just generally playing around with the phone.
Question: To flash a new ROM do I need to restore the system to before I flashed the current ROM or can I just do my wipes and flash a new ROM?
It wouldn't hurt to do a restore, but it shouldn't be necessary (I probably wouldn't bother). Either way, as long as you do the proper wiping in CWM, you should be fine.
Loaded up sonic and so far so good. I didnt even have to do any wipes which I love.
Reactions: brackett5
Yup... So far Teamsonic revolution has been my favorite as well.
________________
Just Flash It !!!
So we can just dirty flash team sonic's freegs3?
//edit: Dirty flash worked just fine for me in case anyone else is hesitant about it.
Nice job on cleaning up the thread Skunk :)
Looks great.
Hey just a suggestion since some guys have more than one ROM posted anyway you can list the actual wrong name to .
Don't quite understand??? An example please.... If you are using tapatalk or another forum software other than a browser. I think I understand your issue. If you are using a browser there shouldn't be an issue as it will show the html codes just fine. But yes I am working on the tapatalk forum issue now.
Edit: Check it now. There shouldn't be any more issues with forum software not seeing the rom names.
Yep that worked. Yeah it just wasn't showing up using the forum software on my phone but you got it thanks.
Yeah tapatalk has a habit of going to town on the more code-intensive guides. My JB guide looks like an absolute disaster on tapa lol.
BTW, thread looks great. Keep it up, this will be a great resource for those with a properly unlockable bootloader :).
ROM Update CM9 Nightly's are back
Kernel Update - By shabbypenguin.
Great job, this is a great resource for you lucky folks with a proper S3!
Sent from my Galaxy Nexus using Xparent Cyan Tapatalk 2
Reactions: Skunkape60
Am I doing something wrong? I'm trying to delete the cpu script from the sonic Rom. When I try it says can't be deleted.
wobblefix
