[SGSIII][Sprint] Android Central Rom and Kernel Library
Re: Android Central Rom and Kernal Library
Am I doing something wrong? I'm trying to delete the cpu script from the sonic Rom. When I try it says can't be deleted.
Do you have permissions? What are you using to edit the script?
I'm using es file explorer with permissions.
Try root explorer. I find it much more user friendly. It has a toggle on top for switching between read only and read/write.
________________
Just Flash It !!!
Figured it out. I'm a didn't have mounted to writable checked.
Re: Android Central Rom and Kernel Library
Does the kettle corn kernel really help battery life alot if I keep the clock at 1512 mHz? Just wondering if anyone that is running it sees a big difference. I would normally flash it myself and see but I'm still trying to understand all the SystemTuner stuff :P
It is an undervolted kernel. So it should be easier on the battery. I will be testing this kernel tonight after I get off work. There were a few bugs in it. So I haven't loaded it yet. I will tonight and well let you know. If you don't want to wait. I understand. :D
________________
Just Flash It !!!
________________
Just Flash It !!!
Awesome thanks, I think I'll restrain myself long enough to read your review lol :D
If you are going to flash the kettle corn kernel, flash this one. It has been updated with a fix that will allow the phone to sleep. The thread hasn't been updated to include this version yet.
The kettle corn kernel seems very quick, responsive and stable. I would say give it a try. Use the link above as it has some fixes not available on the kettle corn thread.
________________
Just Flash It !!!
Reactions: Lolanerd
________________
Just Flash It !!!
I'll try it out, thanks. Did you notice any battery improvements?
And on a side note, jellybean is coming :D
Yes the cm and perhaps the aokp versions of jb may be coming but I would miss many of the added things that come with the gs3. They won't work with cm10 or aokp. Tried cm9 for about a day and found it just turned my phone into a faster version of my old nexus.
I'll probably test out the jb Roms when they come out but I don't think that I would like it without many of the bells and whistles that come with the gs3.
As for the battery life on kettle corn. I don't feel as it's any better or worse. But it is a bit faster but really... The phone is plenty fast with the stock kernel. I will continue running the kettle corn for a few days to see if the battery improves but my first impression is it's close to the same.
________________
Just Flash It !!!
Rom update: JELLY BEAN has arrived on a Sprint GS3 near you and the link has been added to the Library. Enjoy.
__________
Just Flash It !!!
By bells and whistles I'm guessing you mean Touchwiz and motion and all that stuff? Yeah some of the apps/features are pretty cool but tbh I don't really use most of them lol. However, to each his own, the whole point of having an android :D
Absolutely... i don't use s voice, but i like smart stay, wifi direct, s beam my daughter and I both have the gs3 and they come in handy. Also all share play is needed as my phone refuses to transfer files via the usb cable.
________________
Just Flash It !!!
________________
Just Flash It !!!
Have you tried using "Camera Mode" instead of MTP to transfer files? That's the only way that I could get mine to work...
I've noticed that my music player fails when I plug in a car charger. I think that the G1 believes that it's a USB cable and since the G1 can only either act as a drive or access the card itself (not both at the same time), I can't listen to music.
Anybody else ever run into this?
It did fine on small files but it would always give me issues when transferring things such as Roms.
________________
Just Flash It !!!
If you overclock this phone it really chews up the battery and spits it out. I overclocked it to 1.7 and the battery went from 100% to 50% in 2 hours with only 30 minutes screen on time.
________________
Just Flash It !!!
Has anybody used the ACsyndicate ROM? If so, is it normal to be on the boot animation for almost 10 minutes now?
Edit: over 15 mins
Edit: over 20 mins
Edit: I did a battery pull and flashed a different ROM
kitlis
