Shapeless icon styles/...need help
superloco831
Active member
Dec 27, 2012
40
6
8
Ok this is happening on my S21 and S22 ultra whenever I use Nova and apply my icon packs and I have tried various packs it's the same results I can never get the shapeless icons they are always in the surrounding circles I go through settings and check everything maybe I have overlooked something but I am stumped so I am asking for help from the community please and thank you Screenshot_20220407-081503_Nova7.jpg
While Samsung has a ton of icon packs, they almost always just apply to Samsung default apps. Everything else gets a circle around it. If you want a more uniform look, you have to use a launcher like Nova.
Here's an example of my home screen. Check out how only settings and internet get the icon. Everything else is just surrounded in a circle =/
But my icons will not take that shape and I don't understand I am using nova with the icon pack and it's applied?
Hello, in settings here make sure reshape legacy icon not toggle on
Thanks so much mustang I feel like I wasn't using my brain power enough with something so simple and you pointed out the problem exactly I really appreciate the help have an awesome day
williestringfield90
