Share photos taken on your Note 8!
I sure hope you did some post to those photos, if not then you’ve got something funky with your camera.
Zoom the first one, just a little and look at the two shadows to the right of the grass clumps and zoom the last photo just a little and look at the shadow to the left end of the log. Both are blue.
I suspect you maybe turned the saturation up or the blue channel or the camera did to try and make the ocean look bluer and the sky also but you or the camera pooched it too much.
It looks to me like that's snow that hasn't melted in the shadows.
Possible but the blue channel is still way to saturated imho. I pulled them into LR and opened up the shadows just a touch and everything in the shadows is total blue. Ugh.
Here’s the jpg after I pulled the blue channel down and desaturated it. Notice the blue anywhere there are shadows and the blue stops at exactly the shadow edge. Also notice the houses in the background on the right. Blue tinted also. The RGB histogram still shows the blue channel blown out. Can’t see or do much with the low res jpg though.
I hope the OP simply PP the photo and jacked the blue off the end of the scale or else I would suggest a camera problem. F
Machetaseo
