Share your Pixel 6/Pro Homescreens!
Minimal here too
Negative ... I installed a third party widget to get double tap to turn off screen.
Ah, ok. I guess I will stick with Nova then. I was thinking maybe I'd give the stock launcher a try, but it sounds like it's not quite as feature rich. I'm assuming that the wallpaper icon color matching (not that I think I really care much about that since I usually just have a black wallpaper) only works with the stock launcher?
Haven't gotten mine yet. Coming tomorrow
Most likely same homescreen as my pixel 5 here.
You will notice the weather info is not under date in upper left corner
it was - now it's gone - how do I get it back?
Long press then customize and turn on at a glance
It is on - also "weather current info" is on. IIRC there were some issues with this on other Pixels
Let me start another thread on this instead of messing up this one.
My p6 the temp disappeared also. It was on in settings. Turned it off then back on. Temp returned. Oh, these pixels!
I've been using Nova for as long as I can remember. Have you tried the Google stock launcher at all? Just wondering how it compares as the stock launchers seem to be getting better these days.
It is there when I get the phone but I like 7 Dock icons and endless scroll on the dock. Also no search bar(It takes up too much room). So all my phones go to this layout. Unless the stock launcher can do this and backup all my folders, I will stick with Nova. After years of having it this way it is easy to remember where everything is. My brain isn't getting any younger. lol
Koyoiola
