sholes 2.0.3
lol,ya, just couldnt wait. plus the news of 2.1 sucks anyways. figured just go for it. only sucky thing is i cant get that overclock app,the paid one. i have the free one. cant figure that one out.
Try signing in to gtalk then try again I had this issue on another rom let me know if that helps
You hav to set auto detect on set cpu and you should be able to overclock to your heart's content
Look on taz's subforum ay alldroid it was posted their under the 800 overclock
What do you have in your system app as far as gtalk whatever you don't have I can email you or post it here to see if that works. Or you can reflash the rom and not remove gtalk
damnnnnn, i gotta go to work, bizz, u gonna be on later? i get done at 1030. i look under system apps running and its there. wth? i will look u up at 11 bizz, or im the am. thanks a lot for the help everyone. i hate work.lol
Work is awesome. I love work. :p
gtalk or gmail whichever you can. but do you see these in your system/app gtalkservice talk and talkprovider
if you have all 3 apks you should be fine and have gtalk just reload the rom you or go back to 2.02 this may be an issue with 2.03
fyi the superuser app is the application that pops open menu with "allow/deny" options when another application requests to run as root. So if you used setcpu app, the first time you run it, a popup comes up saying it wants to run as root, will you allow it.... That is the superuser.apk application. If you click into the superuser app at a later date it shoudl list processes that you gave access to. But you really never need to open that app unless you wanted to clear them all out. "Root" is obtained because your user can run the "su" binary which allows you to switch to the root user which on linux has all permissions to do whatever it wants (i.e. modify files that normally can't be modified).
ok i have a question for any smupdater wiz.....i went back to 2.0.3 and everything went well,except when i go back into smupater now,its asking which rom i want to install....i select 2.0.3 and it says probly shouldnt download sholes2.0.3 rom tar ,we problly shouldnt dl the tgz agin. dl tgz or flash tar?
i just finished doing this... from what i gathered, the first reboot process was to root the phone, the second one is to flash up to a different rom.
i also didn't get the language. i'm guessing they have to do that to keep from getting sued?
everything went swell for me, setcpu included.
champkbillu
