ok,well,i guess what im getting at is...do i need to check the smupdater daily? because there is nothing i can do on it. it just asks me what rom then thats it. is that all i use that for?
so when something new comes out,itll be there asking if say i wanna download rom 202 203 or 2.0.4? if 2.0.4 comes out, will i have to go to sholes to dl it? or can i do it from the updater?
I was using smoked glass v4 but decided to try this out today. Honestly it's almost identical. I do love what they did as far as creating the update app tho. Makes it super easy. I think I'm gonna switch back though. Especially now that I've gotten used to using the swype keyboard. I just don't see anything that makes 203 better then what I had.
With the sholes rom its what you can't see that makes the difference like flac support the updater the installation process the way you can pick and choose what you want in your rom that makes a big difference to me
