sholes 2.0.6 live wallpapers
Now that I'm running driodmod 1.0 none of my corporate syncs work. Everything was working great on sholesmod 2.0.5 ...corporate push email now fc's and pure calendar widget does not list corporate linked calendar. Reinstalled 1.0 twice with no success. I want my sholesmod 2.0:5 with smoked glass back, where everything worked. Driodmod should have previous versions still available!
Unless you deleted them off your SD card those ROMS should still be available for install. Simply boot your phone into recovery mode. Hold power and X while powering up. Navigate to install using the volume key. Select install w camera key. Select install from SD card and install the rom you wish. My phone still has the 2.0.3 and 2.0.5 as well as the DM rom 1.0 avaible to choose from. This should allow you to flash back to a previous ROM.
On the subject of libe wallpapers.... I know this should probably be in the "apps" section. but this is for rooted devices with live wallpapers and is such a niche application, I figured I'd post here...
I loved the "water" live wallpaper with the little ripple effect, but the image was a little ... weird... anyhow, I found a free live wallpaper app in Market called "live waterpaper wallpaper" - you pick any file from your Sd card and make it wallpaper and then a swipe or movement on the home screen makes it ripple. You can also set it to automatically do a slideshow from a folder or enable the ripple with the accelerometer. This is an incredible live wp app.
thats pretty cool.
Got it, back to what I rooted for. Thanks a million
My battery seems to be draining kind of fast lately. I check the settings / about / battery use area and (of course) display is eating up the majority. Does "display" include live wallpapers? Or, is live wallpapers under core functions? or is it a seperate area and is actully too small of use to really show up and i'm just imagining faster battery drain?
i think it falls under display....anyone?
nope live wallpapers should be under system. or at least thats what i have been told could be wrong though
Random shutdowns or reboots
I have been getting a ton of them lately. It seems to happen most when I installed my 3D launcher. I switched to the new sense launcher but same thing. For now i'm just running the DM 1.0 as is without installing any additional .APKs and its been more stable. For some reason it also seems to be getting warmer faster than before despite lowering my CPU speeds as compared to the previous two versions of Sholesmod. I'm thinking about reverting back to 2.0.3 since for me it was stable and ran super fast for my needs. I'm gonna run DM 1.0 for one more week and see if it gets any more stable.
My wallpapers have started acting up.
Sometimes just going to a blank black screen.. other times freezing.
Still not a big problem though.
Don't use the 2.1 launcher it isn't stable stick with the 2.01 launcher or gde if you want interactive Live wallpapers
Me too. not a lot, just a little laggy. I get either a black screen for about 5 seconds after "waking up" sometimes. or, I'll be doing some hard-core droiding and I return to home and it has just the wallpaper and no icons for about 5 seconds. It's not all of the time. But, getting to be a bother.
I should be used to laggy screen changes -- I come from blackberry
hey quick question, so these live wallpapers, do they stay active when your phone is in sleep mode/lock?? just flashed 1.0 tonight, kinda curious how much of a battery drain they are; worried ole droid will die in my pocket tomorrow
kevin_bkt
