Shortcut to battery settings in Go launcher?
pcguys
596
8
I can't seem to figure it out
Thx
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
long press screen, scroll icons at bottom to the left, tap "short cut" (2nd from the end) tap "settings shortcut", tap battery :)
Thx, I was able to shortcut settings but not battery directly. Am I missing something?
when u tap "settings shortcut" it should take u to another list of parts of the settings with "battery" in it. im using european s3 though
yes, that's exactly what I'm trying to avoid.
Call me lazy, but I don't want to click a setting shortcut, then have to scroll down to battery to click that,
any way around having to do that?
thats what i mean. when ur settin up the shortcut theres a direct shortcut to battery within the settings shortcut that puts a green battery icon on ur screen. maybe its just on international
I ended up reinstalling gsam battery monitor. Originally,I didn't want a widget chewing up battery. This time I only created a shortcut to it so one press tells me the battery level.
Problem solved.
Sent from my iPad using Tapatalk HD
cool man. guess it must just be the international that gives battery shortcut. can i recomend Battery Notifier. check it out man its free and much better than the standard battery percentage in status bar
slackingfred
