Should I purchase Launcher Pro Plus or wait for Froyo?
Stupid Question
Have to agree with clearing the philblur home screens. Seems to have made a difference.
If I uninstall LPP+, and clear my original screens, will the market/website remember that I bought the app when I go to reinstall??
Sorry, new to android, know that Blackberry would remember your device ID.
Thanks
+1 more for LPP. You can customize every aspect of your layout. Add Multicon, Folder Organizer and Beautiful widgets and the possibilities are endless. Best $3 I've spend on the market...though easy root is right up there as well.
Download whatever is on the Marketplace (free version) AND the icon pack - very cool stuff. The free app will ask if you want to upgrade to the paid app and take you to the website to do this. All very simple.
Once paid and installed, if you uninstall, you will need to real-download the free version. Then hit menu and input the activation key code (can't think of the actual words they use). Be sure to save activation key code you receive via email at purchase. You will need it any time you re-install.
PS - once you buy from the Marketplace, they keep at record of your apps and will tell you those with updates when you check "my apps". Downloads are as soon as you touch the word, direct to the X. Very slick.
Another PS - I will LOVE Swype.
Prince08900
