Shutter sound. (probably asked before)
Where is this Odin one click exe that we need to run? Can you explain that a little? Thanks.
i can't seem to get my phone into download mode. Is there another way?
sorry but still can't get it, got the one click downloaded and opened, put phone in download mode, plug phone into computer but nothing happens. Tried multiple times and same result, I hit start in the Odin one click and it says success 0 fail 0. Please help
When Odin open, look to see the word added where you see the failed at. You should also see a yellow box. When you see the yellow box press the start button. Then you should see a green box moving. It is showing you the download progress. Once it is finished you will know it is done.
Billard412,
This worked perfect after I realized the phone has to be turned off to access the download mode. Can't thank you enough!
Steve
Doe anyone know of a way to remove this from the phone? I am having some problems with my phone, unrelated to this, and I may need my phone replaced. I don't want Sprint to say that this is the cause of the problem. So is this reversible?
Download an app called camera jb+ you can turn off shutter sound
I have used Camera JB+. Its works pretty well. I just prefer the stock app.
I'm in the middle of downloading the file. Do I need the Odin one-click or is it part of the file? Thanks.
Hi all. Trying to follow the directions in this thread, but when I go to the download in the xda forums, I get this -
The file you requested was not found
Lets see if we can find that for you...
Does anyone have another link to the file needed? Thx for the help.
jeffnachatilo
