Sick of Custom Roms
Does this kernal drain your battery? Seems to be draining faster than normal...Maybe a few reboots to settle it down?
It must have settled down, i have going on my second day now with normal use, and i still have just under half battery.. Great kernal..
Now my last questions.. i renamed the com.htc.TwitterWidget.apk to .old and the Friend stream widget, and now when i add a widget i have two that are in the menu that say False and htc.. when you click it crashed and you have to force close... so do i need to change the name of those .apk or can i leave the widget .apk since i have renamed and gotten rid of the actual .apk for the apps.. hope this makes sense.
When you disable the app the widget icons will stay in the Widget List because they are in a separate DB from what the app drawer reads. From what I understand, you would have to go in and modify the actual database itself to get rid of the widget list items.
For what it's worth, they are not doing anything or taking up any system resources - I'd leave them.
In what folder is the stock htc keyboard? I want to remove it and put in the gingerbread keyboard.
You don't need to remove it. Just put the gingerbread keyboard on your sd card, update zip from sd card in recovery and reboot. Once the phone is rebooted, long press where you would normally type. Select input type and pick Android keyboard. You then be using the gingerbread keyboard.
I love it. It is SOOOOO much better than the original. My only beef is the comma is not on the front page anymore. That's it. Predictive text is better, the portrait mode is FAR mor accurate, and lets face it, the black is much sleeker look than the white.
I know how to install it.. but me being some what of a perfectionist, I wanted to remove the old HTC keyboard completely. I will do some digging!
just delete the apk. it'll be in system/apps and named LatineIME that might delete the drivers and make other keyboards FC tho
why delete the bloat ware apps. I use Titanium pro and just freeze them, seems to work great, I can always unfreeze as needed
I did it just to see if i could.. you know actually using adb shell and connecting to the phone.. I have though it would be fun. and it was, now I really want to get into making roms. Time will only tell!
bea andrews
