Skins- Is there any way we can get more skins?!?
All m skins from XDA are gone. Even the one skin that actually bought on the market won't show. It install but nowhere to be found to apply it. Stuck with the same 5 lame skins that came with the phone. I have all the apk skin file from XDA saved. They just won't installed.
If you downloaded the skins before GB, then they were for Froyo and they won't work. If you just downloaded them from the link that was posted earlier you should be good to go. Make sure you name the file "skin name".apk (if dloading on phone) and use a program like Es File Explorer to install. Locate file in download folder and click on it to start the installation.
sooooo complicated.
Tfunz
