Skyraider 4.0 Available Now
Random question to you, a random persom online...do u know if its common for hulu and adobe flash 10.1 to both work flawlessly at the same time on SR 4.0...? A response will be greately appreciated...
According to xda's website regarding skyraider 4.0 you have to use flash 10.1 do not upgrade to flash 10.2 or hulu will not work correctly
sent from my TB via tapatalk
Seth is correct - hulu has to be hacked to work on Sense so the hack has to match the flash version it was hacked to. If you upgrade flash, hulu will stop working.
How do you upgrade Flash? If trying via the Market, the update fails. I don't use Hulu anyway, would rather have Flash that is up to date.
If im not mistakin, u can't update flash in this version of skyraider... U don't need to anyway... It will make no difference.... PLEASE click on the XDA link on page 1 of this thread and read through the xda thread about skyraider 4.0... All the info u need...
Reactions: Wanda
To prevent the flood of hate mail to the dev for "breaking hulu" most dev's that provide hulu also place flash in the system partition where the market can't update it.
As seth said - it's not a big deal. The dev will eventually update it and re-hack with the current version of flash.
i just tried to flash this rom now im stuck at the white " htc incredible" boot screen im scared my phone is bricked please help me asap thanks
List the exact steps that you used to Download the ROM and flash it... Did you do a full wipe (wipedata/factory settings, cache, and dalvik cache- under advance menu) ? did you install through ROM manager or through Hboot? I prefer Flashing any new ROM through HBOOT mode? as for right now, do a battery pull, try again by holding volume down and power at the same time for HBOOT, if that doesn't work then go back to your most recent nandroid backup and start again from there.... I am going out to eat but will be back...
yes i did a full (wipedata/factory settings, cache, and dalvik cache- under advance menu) then the rom was flashing and when the rom tried to reboot it never went passed the white " htc incredible" screen. When i get into clockwork mod recovery when i select and option i see the rom manager hat and an arrow inside of it? dont know what this means
In recobert if you see the hat logo with no text just click the power buttong and it will take you to the menus.
Try re-flashing. If that does not work, restore with your nandroid and re-download and try again.
What version of CWM are you using... According to XDA is requires a 3.x.x version... If your version is 2.x or 4.x you need to select a 3.x version under OTHER CLOCKWORK MOD RECOVERIES
And As I said... If that doesn't work, revert back to most recent nandroid and try to start over again... could be a bad DL... keep me posted :)
its cwm 3.0.8 once i select to restore once i select using the power button nothing happens all i see is the rom manager hat with the circled arrow
Im guessing your trying to restore your most recent nandroid backup as mentioned in above post by Pville and seth and its not working ? :confused: Or is it something else ? Are you trying though Rom Manager ?
If trying to restore an didnt work ,,how about restoring it though Hboot and see if that works
Hold volume down at same time hold power button in.
Once there use volume to toggle to "recovery" Use power button to excute ,it will boot into CWM
Use trackball pad now to scroll to ,,"back up and restore" once there push trackball in to select it.
Basically once in CWM use the trackpad to select option and to excute with as well.
thanks so much my phone is now working from my last nandroid back up. i used unrevoked3 to root my phone and since this wasnt the best experiment what is the easiest way for me to get root access of my phone?
If you're running the last nandroid backup you made you're still rooted. Just reverting back to your first backup you made before you tried to flash this ROM does not take root away.
For flashing ROM's I'd read the thread about how to do it first and then do it the manual way, that is basically what you just did if you followed davidnc's instructions to get your backup running again. The process is nearly identical. I would stay away from ROM manager for flashing ROM's as this is often the source of "hey, why didnt this thing flash right". It's a handy resource for downloading ROM's and making backups but if you want painless flashing, do it the old fashioned way.
Reactions: zero neck
I really hope you get this ROM working... when I had my incredible, this was my absolute favorite....
ips gaming 88
