So, are they ever going to fix the GPS?
Piizza,
At last check, Faster Fix wasn't working for me after the GB update. I noticed a couple of other people had made comments indicating the same thing on the Android Market. Is there a trick to getting it to run?
First off I didn't realize I posted the same advice twice...my apologise to the group
No trick for me, it just worked as intended. Maybe they pushed an update since you tried it last
Sent from my SCH-I510 using Tapatalk
Someone commented that with the Charge, once they updated it to 2.3, it didn't work anymore. I downloaded it but haven't tried it yet because of the cave I work in.
They must have updated it, but I also didn't realize that I needed to install Busybox, so that was my other problem. I'm new to this rooting thing still, but I'm learning!
Worst case scenario, you can always have a bowl of water and place it on top of a floating cork. Where ever the top of the unit points is North. That'll give you an idea which way you're headed.
good luck. :D
good luck. :D
Please don't give Samsung any ideas!
Future unboxing:
- Phone
- Battery
- Charger
- Data Card
- Sim Card
- Useless Instruction Book
- Wine Bottle Cork
- Small Plastic Dish
- Sticky Disk to attach Dish to Dashboard
My GPS has worked from day one, but the problem I have as others have mentioned is that it takes quite a while for it to lock on, especially when moving. I downloaded the faster fix app and froze angry gps with Titanium Backup, so hopefully it will work better.
witnessloc05
