So I dropped my LG G3 ......
I recommend a case like this, it offers a textured grip but doesn't remove the G3s good looks.
Knock on wood. I really have been lucky with my drops. I have dropped every phone I have ever owned including my G3. Today I wore some pants with loose pockets and I dropped it atleast 3 times getting up from my chair. My wife had a G2 (my old one) and the 4th day she had it my daughter knocked it off a 2' tall coffee table and the screen shattered. I repaired it myself because Sprint's ins. wanted a ridiculous amount of money. She is staying with the temp replacement LG Marquee because it has fallen several times with no injuries. Btw the g2 was pretty easy to repair because you can buy the digitizer and screen in one piece.
So it's a piece of glass you glue over your screen? Does it interfere with cases? Is it flexible?
I got an Incipio case for my G3 the day after I bought it. Just thinking of me dropping it was enough... Gives me some comfort in case...
Sent from my LG-D855 using Tapatalk
You can always try using a clear skin on the case itself. I have done that before with cases I really liked but that were too slippery. XtremeGuard are decent and really cheap and will give you tons of grip on that case.
Is it the Dual Pro?? Thats the one I'm currently looking to get. I like the thickness the case gives the phone all around and the fit is pretty snug/tight so if the device falls, the case won't come flying off on impact.
lusiee
