[SOLVED][Android 4.1][iOS] How Emoji works on Android and iOS
[...] WRITING emoji seems to depend more on stock Google Android having the emoji keyboard as described above. Non-stock-Google needs something like Multiling Keyboard.
So as far as I know, any manufacturer that implements Android 4.1 "properly" should show emoji. That is, you can SEE it. Like I said do check the Wikipedia page on various devices and let me know.
In summary, any 4.1 device like S3, One S, etc should SHOW emoji (like my One X), unless the manufacturer didn't do it "properly" for some reason. S3 and One S will need Multiling Keyboard to WRITE emoji because it is not stock Google Android.
[...] Sent from my Nexus 7 using Android Central Forums
SO I now understand-ish why my JB s3 phone does not come with the AOSP keyboard (becasue the s3 is not a stock google Android...?). I guess the next logical question woud be, is there any way to manually download the AOSP keyboard, capable of adding on dictionaries (i.e. emoji for english words)???
I downloaded the Android Keyboard (LatinImeGooge_signed.apk) from here: ? Configuring your Samsung Galaxy S3 for Blind Users ? Part 1 ? Getting rid of the samsung keyboard in favor of the android stock oneJeffrey's Soapbox but it does not have the "add-on dictionaries" option. I am grateful to now have autocorrect and a properly-spaced spacebar, but where can I find the real deal?
Screenshots: 1) before android keyboard download. 2) after DL 3) options provided within its settin
it seams mine is not working properly as you have said. i add on dictonary but it goes away. and the little sign does not appear. i have the droid razar maxx hd
Too bad the Android emoji suck.
Whoever designed the Android smileys should be abused.
I think they got one of the programmers to do it in his spare time rather than actually hiring an artist. The icons lack wit, charm, and clarity.
now i have an android 4.1 HTC EVO 4g LTE and i still dont have the emojis i can see them on ig but i cant send them or see them when they are sent to me so what can i or do i do
So is it safe to say that android users are not able to use emoji's on instagram with the stock setup on the GS3? :'(
That dpends what you mean by stock, if tis not include installing extra appictions, you might find keyboard that can place emoticons and just install it :> just search :p
I have the Droid RAZR Maxx and I can see the emojis but when I go to add on dictionaries and download the add on it doesn't work. I go back to look at it I it disappears. I refresh the page and its there again but I have to re install it again. Does it work for my phone?
I'm having the same problem with my original Droid razr. I can see the emoji on Instagram, etc. But i can't type it. I tried to go into settings and found where the emoji keyboard is but it doesn't want to "stick". after i install it, and refresh or leave the settings, it says uninstalled. How can I fix this?:confused:
I have a Droid RAZR MAXX and have the exact same problem. I install the emoji dictionary, it disappears when I go back to that screen, refresh, then have to install again. Its a continuous loop.
Yeah it looks like standard emoji without colour is usually the best we can get for now. Someone should make a root modification or otherwise hopefully Android 5 will have colour emoji.
Have you tried Multiling Keyboard?
Have you tried Multiling Keyboard? That's what works for me...
Re: Ios6 vs Windows
Is there a link to anywhere on the internet that shows almost all or all of the ios 6 emojis next to their cross platform windows equivalents? That would be super amazing. I want to know what each emoji looks like when i send an ios6 emoji to my friend who has a windows phone
Yup Wikipedia has a good run down/ comparison.
I tried all of this on my HTC One X+, and I cannot type Emoji. I able to read them, and Emoji keyboard is "on" in settings. However, there is no way for me to type with Emoji. It would be nice to be able to switch between my regular Swype keyboards and an emoji keyboard. Please attempt to fix this problem. Thank you.
Have you tried Multiling Keyboard? I don't work for them but that is what I use to switch between Swype/Touchpal and Emoji.
Re: [EXPLANATION][Android 4.1][iOS] How Emoji works on Android and iOS
I can't install Emoji for English words... It would install but then delete right away. I tried refreshing like 10 times and it keeps doing the same thing.... Please help me!! I have Nexus 7 :'(
Wow.. This just confirms it one more time. Another point to the iPhone team. : (
I thought there was a way to integrate iPhone emojii into Samsung and Swype keyboards and use it just like with iOS, and there is no such way. Sucks.
Recently Google has released it's "Google Keyboard" in the play store. This seems very similar to the Android "stock" keyboard. So if you have an S3 etc. that uses it's own proprietary keyboard you can install the google keyboard and enable the emoji dictionary with no hiccups. I have been using this new keyboard over the last day or so and so far I love it.
Still would like to see a list of all the keywords to activate all of the emoji's though....
It is the Google stock keyboard, just with res and layout folders for all devices and backwards compatibility for older versions of android. The source code is nearly identical, I can tell you for sure.
Sprint GS3 Running TN's Msg and Chubbs
pamatika
