[SOLVED] assert failed
HI im using Xperia mini pro(sk17i) running on ICS 4.04. I'm getting installation aborted error even after deleting assert script also. Please do me some favour
Wrong device forum, but aborts can happen if your device has insufficient free space to fit what you're flashing.
You just like a god to me!
I bricked my device, so i downloaded stock rom.
After that assert failder error show!
And Sir, Your Trick Works Totally!
1000 Thumbs Up !!!
how come every time i delete the line in notepad ++, i save it and then i refresh the folder, click on updater-script to make sure and it keeps coming back! i keep deleting the first line but it wond go away. how do i fix this?
I find if you go into notepad ++ and select 'edit - clear read only flag' then delete the line and then choose save as and save it to documents 'all files' (not .txt extention) then copy the file from my documents you can past that back into the zip file and it will compress automatically (in windows 7) hope this helps
It doesnt work when i try it
it says
set_metadata_recursive: some changes failed
E:Error executing updater binary in zip '/data/media/o/sideload.zip
when i try to install via adb push, it says
E:Error executing updater binary in zip '/sdcard/gapps-51-arm64-2015-05-03.zip'
Error flashing zip '/sdcard/gapps-51-arm64-2015-05-03.zip'
kctraci1
