Sound issues; feedback/crackling noise on speaker or with headphones
shadesofgreymoon
So about 4-6 weeks ago my tablet started to have a sound issue. Essentially any interaction on the screen like key presses on the virtual keyboard or the play button on a media player--seriously anything--causes a sort of feedback crackle/squeal.
It typically occurs with just the first press, and then either occurs at random as typing continues, or sort of "resets" if nothing is pressed for a short period. While it usually only sounds off for a second or two, it can progress into a 10-15 second long squeal. Restarting the tablet after the issue has begun restores things to normal until the problem randomly crops up again.
As I've mentioned, the sound occurs either through the tablet speaker or through headphones. Having sound disabled for keypress does nothing. I have already done a factory reset. The tablet has not been dropped, exposed to water, or otherwise potentially damaged. The only thing that has changed is perhaps an update to the Android version?
I'm at my wit's end with the problem. My warranty was up in February, and as a disabled person I both rely heavily on my tablet and can't afford to replace it or pay for expensive repairs. If anyone has any ideas or has even heard of such a thing, I'd love to hear about it...
This exact same thing is happening to me! It's a weird staticky sound, no? I keep worrying the hardware is breaking down. It has been happening for weeks - maybe months - and does it even after doing a factory reset. Part of me wonders if it's a driver issue after the Nougat update. I was initially really freaked out that the hardware was degrading, but since then, it just sort of sits in the background until it happens again and then I roll my eyes and restart it.
Weird I had the same problem around the same time after update from T-Mobile and Google.
I hope another update will fix it,
I have no idea how to approach to fix this problem?
I did a hard reset and cleared the cache too!
Always do!
FYI this is a New Replacement Tablet too.
Factory firmware was installed.
Other than getting another replacement tablet I don't know what to do?
montesjony0611
