Sound keeps muting, but volume is at maximum
debsawyer
296
Nothing seems to work right, battery sucks, OK Google grayed out, and my freakin' sound keeps muting, and the sounds are all the way up. What is going on? After two resets, and 10 times cleaning the cache, I am just fed up. They need to fix this darn Note 4 before I toss it out the window!!!!!!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,612
4,757
113
When you say you cleaned the cache, do you mean the system cache partition? https://support.t-mobile.com/docs/DOC-14686
Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-14673
If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
sdaservices2000
