Sprint Kingdom ICS 3.14.651.0 SYSTEM and Boot DUMP Complete
this Dump worked great! got my design to boot up! now i accidentally clicked on the lawmo lock 1234 under the API menu that i ran under terminal.
now when i unlock my screen it prompts me to input a Password to unlock my phone. is there a way to fix this?
thanks
This is what I have 4.0.3 ICS on freedompop phone they gave me the design. Also with kingdom listed in details, although with freedompop profile.
You posted the same link to dowoad on post 1 and in post 9. Can you please repost a stock ROM that works on cwm recovery mode and we dont need to unroot or relock bootloader to install. Many thanks
hi i need help becose delete the system of my evo design and delete the backup too then i have a question i can install this rom? on my htc evo design although dont have any siyten inthe phone??
my phone is rooted
Well for anyone that doesnt know me I used to develop for the HeroC and SHIFT on XDA, due to having to help a family member through Cancer recovery I left the scene for a little over a year, I am back around again.
This is a complete system dump of the ICS release from Sprint with the personalize update included.
This is a complete Dump, only extras in it are SU binary and Superuser.apk.
This can be used by anyone for any purpose they want, I just havent seen an actuall system dump around for the Sprint users so I created one.
I will also be creating a PH44IMG.zip you can use to restore your phone to complete Factory stock ICS, for those having ISSUE's with something. This will be in a post of its own.
Remember this is full stock system and boot images......
Android OS Version :4.0.3
Device :kingdom
Model :PH44100
Build :3.14.651.0
Carrier :Sprint
Kingdom_Sprint_3.14.651.0_system_boot_dump_full_stock.zip - 451.23 MB
dont need fastboot , just boot to bootloader it should take a few then you will see it scan the zip and ask if it should apply it.
Also make sure the zip is on the root of the sdcard ( not in any folders)
this update cid gives me an error when trying to install hboot plase help me
Please can somebody help me ?? I get CID incorrect incorrect when trying to aply this file ... my phone is stuck in the boot screen and only thing I can get is to bootloader and recovery but hard reset is not working and my only hope was this file :(
Maybe someone can help me? I have a boost mobile HTC evo design. the phone slowly lost battery life and eventually the battery just stopped working. i would have a full charge and the minute it came unplugged it would drop down to 8%. I got a new battery when the battery no longer held any charge what so ever causing the phone to not turn on all the way. When i inserted the new battery and tried to power on the only screen that would come up was HBoot. I eventually got the phone to power on, but now after only being on for a short ammount of time it will shut off and turn on without me hitting the button and continue the cycle until i pull the battery out regardless of me using it or not. it will not do anything; apps crash upon opening. When i first get into HBoot a list of errors appear, saying that my image file PH44100 doesnt exist. I cannot factory reset the phone, it will not let me. everytime i try to do so in HBoot or the other stock reboot or from the actual phone settings it crashes. The phone is not rooted, nor will my computer recognize the device upon plugging it in.
Nammna
