Sprint LG G2: Battery sucks!
Not a problem, Julio. Let us know how it goes.
Sent from my LG-LS980 using Tapatalk
Gonna Say This Is The Problem ?
Yes. Google+ is your problem... How in the hell it's keeping the phone awake like that baffles me, but definitely do something about g+. 9hrs is ridiculous.
Uninstall updates and reinstall them, or just disable it completely if you don't use it. You could always use the mobile Web page too though.
Yes Google+ is definitely your problem. I wish Google would resolve this. I had an issue were Google+ ate up half of my data allowance in like a half hour. I bet it has to do with auto backing you photos. I would go into the setting for photo auto back up and make sure it is set to only backup when on the charger and only back up when on wifi. That way you still get your photos backed up and it doesn't eat up your data or your battery. Also I went into my data manager and restricted google+ to use background data only on wifi to be sure. Make those changes and you will get the stellar battery life you were hoping for ;-)
ಠ益ಠ
ಠ益ಠ
Ok Soo Google+ Has Been Disabled But My Battery Stills Drainging The Same
Heres The Cpu Wakelock And Wakeup Triggers
Statistics over two minutes won't give much info. It's much easier to gauge when you leave the phone off the charger for a few hours. Gives the apps time to engage *** mode. Haha
Im Really Aggravated With This Phones Battery Right Now , And I Have No Clue What To Do
