Sprint Note 9 does NOT have Calling Plus
Have any of you had the issue reoccur after updating to Android PIE. I have, cant even uses the process below because it doesn't appear at all in the shortcut tool.
It's broken after Pie Update :(
My guess is that the reason is that the previous method was a sort of hackish workaround and Sprint purposely blocked it with their Pie update.
I did the fix and it worked great then the update came along now it doesn't work anymore can anyone help
Read this. You have to downgrade to Oreo. (Don't forget to back up everything - flashing a ROM wipes the phone. And don't forget to do a factory reset first, or you'll end up in a bootloop.)
Starfleet Captain - I downloaded the 'Shortcut Master (Lite)' - opened the app & clicked on 'search' and searched for "enhancedlte" and there are 0 (zero) results.
Any other clues?
Any other clues?
liquidsnake757
