Sprint Releases Jelly Bean Today!
So, I did a factory reset. What happened to the Task Manager?
Sent from my SPH-D710BST using Android Central Forums
What's your problem with it? It's still there. When you long press on the home button it's the pie chart in the left lower corner of the apps list.
Thanks for the tip. The problem I have with it is it no longer listed in my app drawer, applied the Task Manager widget instead. The are other problems after the reset. One problem is SwiftKey will not stay as my default texting app after I power off my phone. Maybe it will work itself out after a few days of running.
Factory reset didnt help my battery woes. Also...cant take a screen capture. Tried Power+Home and Power+Vol (down)
Press first Home, as soon the other lights up, then Power for about two seconds, release both at the same time.
Sent from my OM SPH-D710 using Xparent SkyBlue Tapatalk
Just switched from the HTC Evo 4G LTE to this. Wanted something a little smaller. Why all the hassle to get JB on here? Why isn't it just OTA?
Sent from my SPH-D710 using Android Central Forums
Because they say the Jellybean update is to large for OTA.
So I downloaded & flashed a rooted stock version of GB27. How would I go about removing root?
Prince08900
